Postovi: 33
Konfiguracija za igranje do 10.000 kn
Kompjuter bi bio namjenjen vecinom za igranje i rad u officu i slicnim programima ( ako bas moram ) ![]() ![]() |
Postovi: 7,568
Prijedlog:_________________________________________________ Zadnje izmijenjeno od: McG. 05.06.2008. u 10:22. |
#3 | |
Lokacija: N/A
Postovi: 1,242
THERMALRIGHT Ultra 120- eXtreme - links.hr - 393 neki vent 12cm - bilo gdje - 50 MBO DFI LANPARTY UT P35-T2R - links.hr - 1539 CRUCIAL Ballistix, DDR2 667 MHz, KIT 2x1 GB - links.hr - 369 ili CRUCIAL Ballistix, DDR2 800 MHz, KIT 2x2 GB - links.hr - 699 Ati Radeon HD 3870 X2 - adm.hr - 2349 ANTEC P182 - adm.hr - 989 CORSAIR 520W, HX Series - adm.hr - 660 dvd - bilo gdje - cca 200 hdd - zavisi sta trebas - samsung, seagate, wd - 600 EDIT: da napomenem da i za 6k kn mozes slozit gamersko-OC zvjer, a da je 10k bacanje para u vjetar |
klanfa
Lokacija: ZG-Dubrava
Postovi: 494
MBO Abit IP35, P35, DDR2, zvuk, G-LAN, FW, S-ATA RAID, PCI-E, s. 775-links-802,33 kn RAM PC-6400, 2 GB, CRUCIAL Ballistix, DDR2 800 MHz, KIT 2x1 GB-links-389,00 kn Procesor Intel Core 2 Duo E8400 , 3GHz, socket 775, 6Mb cache-adm-1.179,74Kn VGA Ati Radeon HD 3870 X2, 1024Mb GDDR3, Dual DVI, PCI Express-adm-2.349,36Kn HDD WD 750Gb, 7500AAKS, SATA II, Buffer 16Mb, 7.200 rpm , 8,9 ms-adm-969,63Kn Napajanje CORSAIR 650W, TX Series CMPSU-650TXEU, 12cm vent,ATX2-adm-594,21Kn DVD upisivač Pioneer DVR-215DBK, DVD±RW, 20x DVD±R ,12x DL-adm-190,11Kn SCYTHE Zipang SCZP-1000, socket 478/775/754/940/939/AM2-adm-424,44Kn ANTEC P182 EU-adm-999,52Kn Ukupno : cca 7.900,00Kn iz linksa i adm-a
Datum registracije: Mar 2008
Lokacija: Hum na Sutli
Postovi: 104
MBO ASUS P5E3, P5E3, 775, Intel X38, ICH9R, BUS 1600 MHz, DDR3 Procesor Intel Core 2 Quad Q9450 , 4x2.66GHz, socket 775,12Mb RAM 2x DDR3 2Gb (2x1Gb) Corsair, 1333MHz, 9-9-9-24, TWIN3X2048-1333C9DH VGA VGA Ati Radeon HD 3870 X2, 1024Mb GDDR3, Dual DVI, PCI Express HDD 2x HDD WD 500Gb, 5000AAKS, SATA II, Buffer 16Mb, 7.200 rpm , 8,9 ms CPU cooler SCYTHE Mugen SCINF-1000, Socket 478/775/754/939/940/AM2 Napajanje CORSAIR 650W, TX Series CMPSU-650TXEU, 12cm vent,ATX2 DVD upisivač Pioneer DVR-215DBK, DVD±RW, 20x DVD±R ,12x DL THERMALTAKE Soprano VB1000BWS, MIDI, black, bez napajanja Evo sve iz ADM-a za 10.348,53Kn Ali ovo ti je bacanje novaca... Ko voli nek izvoli... |
Postovi: 33
Hvala svima na prijedlozima, svi ce biti uzeti u obzir, monitor za sada je to hpL1815 , makar cu i njega mjenjati... ( al za njega mi nije bila potrebna pomoc jer relativno jednostavno se moze doci do toga koji je trenutno najbolji ili best buy, a za ostale komponente bi mi trebalo puno vise vremena, kojeg nemam i izasao sam iz stosa vise toliko ne pratim napredak hardwarea ) Eh da nesto sam zaboravio napomenuti s obzirom da ste mi preporucili dvojezgrenog radeona ( u buducnosti bi ubo i drugi pa ih stavio u crossfire, kada komp pocne kasljucati jel ) moje pitanje je slijedece da li je u dosadasnjim postovima napanje dovoljno za guranje dvije takve kartice u crossifereu i i da li je to podrzavanano od strane preporucenih maticnih ploca u gornjim postovima ( isprivacam se na debiljnim pitanjima al kao sto rekoh malo sam van toga svega vec par godina, a tesko je to pratiti ) Zadnje izmijenjeno od: iroonwood. 06.06.2008. u 08:54. |
Postovi: 7,568
Imaj na umu da stižu novi Radeoni iz HD 4000 serije, te da se u vrijeme kad budeš ti namjeraval kupiti drugu HD 3870 X2 karticu, boljim i isplativijim rješenjem nameće prodaja aktualne X2 i kupnja dvije HD 4870 ili jedne HD 4850/4870 X2 kartice. |
Lokacija: N/A
Postovi: 1,242
ak ces CF ili CFX uzmi minimalno X38 ploču, mozes sad uzet 3870x2 i onda neku bolju kasnije, ne moras istu, nadam se da ce se moći tako, ne vidim razloga zasto ne bi |
Postovi: 33
Pala je odluka na ove komponente pa bih htio vase misljenje vezano uz kompatibilnost svih komponenti medjusobno, posto cu naruciti iz ADM-a pa da ne bi nakon 5 dana morao vracati nesto jer ne funkcionira jedno s drugim ( odustao sam od CF price ), odluka je pala na slijedece komponente Napajanje Corsair 520 W , HX series - 660 Antec P182 EU - 999 kn Ati radeon 4870 - 1750 kn ( da li je bitno da li je Saphireova, Gianwardowa ili cija vec ? ) ovo je cijena za Saphireovu za Gianwardowu se treba dodati nekih 100 kn sto nije bad ako to uopce ima kakvog utjecaja na samu kraticu tipa bolje hladjenje ili nesto ili je to samo marketing ? ASUS P5Q Deluxe,775,intel p45, ICH103, bus 1600 mhz - 1351 kn Inel Core 2 Duo E8400 - 1028 kn HD WD 640 gb AAKS, SATA II, - 520 kn DVD prža NEC-ova - 169 kn RAM PC - 6400, 4gb 2x2 Crucial Balistix, DDR2 800mhz - 800 kn Sveukupno 7300 kn Ajd da opet ne spamam , prijedlozi u vezi NEC-a su uzeti u obzir uzet cu nekog pionera , kako god za ostale komponente sam se vec odlucio dakle to su te komponente koje mislim kupiti samo me interesira da li ce sve skupa raditi medusobno jer cu naruciti preko ADM-a ( sve osim memorije ) iz Osijeka sam pa mi je malo glupo da onda vracam komponente ako nesto s necim ne radi pa opet cekam druge da dodju i slicne zavrzlame. Od CF sam definitivno odustao zbog toga sto eto sto kaze tu netko pametan cemu CF kad za 9 mjeseci izadje nova serija grafickih i pojede CF kao od sale ( ovo je banaliziran primjer ) . Zadnje izmijenjeno od: iroonwood. 29.08.2008. u 12:06. Razlog: Napokon kupovina |
Postovi: 33
Sorry na spamu,al editiranjem posta tema ostaje neaktivna pa sam odgovorio na temu u nadi da ce netko skontati pa odgovoriti, pokusao sam izbrisati prijasnji post, ali nisam uspio |
Postovi: 7,568
Post ti je obrisan, a savjete pričekaj. |
Postovi: 1,530
Nemoj NEC. |
#16 |
P.E.B.K.A.C.
Postovi: 2,304
Pa za tu tvoju lovu mozes imati CF (ako ga bas zelis) Sad sam vidio da je malo stariji topic, uglavnom moj bi bio savijet ovo sa samo jednom grafom 4850 pa kroz sljedeca 3-4mj uzeti drugu i bubnuti u CF da se pocetni iznos smanjiti za 1000kn... (vjerujem da ce se 4850 grafe moci rabljene naci za 600-700 kn kroz 4mj) ![]()
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/ Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Zadnje izmijenjeno od: Gjurovski. 29.08.2008. u 10:19. |
#17 |
Datum registracije: Aug 2008
Postovi: 1
Procesor Intel Core 2 Quad Q6600 , 4x2.4GHz, socket 775, 8Mb G0 1.151,69Kn Gigabyte X48-DS4, s775, intel X48+ICH9R, FSB 1600/1333/1066/800M 1.255,38Kn Napajanje Silverstone ST75F, 750W, Dual PCI-E 6 pin, serial ATA 986,37Kn VGA Ati Radeon HD 4870, 512Mb GDDR5 256bit, Dual DVI, PCI-E 1.749,16Kn COOLERMASTER Cosmos RC-1000-KSN1-GP - srebrno-crno, bez PS 1.297,23Kn DVD upisivač NEC AD 7203S, DVD±RW 20x LabelFlash SATA crn 174,56Kn DDR2 4Gb (2x2Gb) PC8500 Corsair, 1066MHz, TWIN2X4096-8500C5DF 931,37Kn wd 640gb Ukupno: 7.545,76Kn |
#18 |
Postovi: 33
Eto komp je narucen treba samo stici , tema se moze zakljucati, zahvaljujem se svima koji su pomogli pri odabiru svojim savjetima. Navesti cu komponente cisto da eto netko tko kupuje moze si pomoci Procesor : Intel Duo2core E8500 ( prijedlozi su vecinom bili E8400 i poslusao bih al posto sam narucivao iz ADM-a trenutno nije bilo raspolozivo tako da sam uzeo ovaj ) = 1,152 kn Mbo- Asus P5Q Deluxe = 1,351 kn Napajanje Corsair 520 W HX series = 657 kn Monitor - Lenovo L220x 22" widescreen - 3,040 kn Grafika - Ati Radeon 4870 = 1,749 kn Memorija - Muskhin PC -6400, 2x2 gb, DDR2 XP series - 689 kn ( Hg spot ) HD - Western Digital Caviar 640 gb serial ATA II ( WD6400AAKS ), 16 mb cache , - 559 kn ( hg spot , nije bilo raspolozivo u ADM- u ) Kučište je trebalo biti ANTEC P182 ali nije dostupno trenutno inace 1100 kn ( vjerojatno ce tu ici ipak ANTEC 900 - 838 kn u linksu ) DVD - Pionner DVR - 215 DBK - 185 kn ukupno = 10,482/10,220 kn ( ovisno o kucistu ) Molim lock teme |
#19 |
fanATIčni AMDovac
Lokacija: KC-ZG
Postovi: 1,312
Intel konfa do 10k kn(za kolegu s posla)
evo,kako naslov kaze,ovo je tema iz usluge kolegi s posla... dakle uvijeti su: 1.Intel based konfa 2.MORA biti iz vemila(neznam zasto,vjerovatno ima tamo nekog pa moze dobit rabat ili sto...) 3.da se ostavi mjesta od 600kn za kuciste(znaci raspisite se sve do 9400kn) 4.konfa mora imati monitor(pozeljno 22") 5.ovo nije tease tema pa bih molio da svi koji kane komentirati zasto 10k kn preskoce ovu temu.da me pitao da mu slozim neku 10k kn amd konfu to bih znao ali u intel se fakat ne kuzim...kao sto rekoh ovo je iz usluge kolegi,tako da nisu moji novci,jer ja nebih potrosio 10k kn na komp.pokusavao sam ga odgovoriti od te cifre ali nejde... unaprijed hvala svima koji ce postati nesto korisno
#20 |
Lokacija: Vz - Zg
Postovi: 2,930
a sta ce on raditi na tom kompu kao prvo i osnovno? ako ce samo gledat filmove onda neki dobar 24" monitor + pristojno kvalitetni zvucnici i zvucna, ako ce se igrat onda jaka graficka, ako ce obradivat video i fotke puno diska, raid polja, brzi quad core procesor i puno memorije 10kkn nije jako puno novaca da se moze svega na bacanje natrpati, tako da je namjena vrlo bitna
#21 |
fanATIčni AMDovac
Lokacija: KC-ZG
Postovi: 1,312
pa koristi ce ga za kucnu uporabu(ono filmovi,igre,internet browsing itd.) ali ce ga također ponekad upotrebljavati i za CAD i slicne aplikacije pa zato i uzima jacu konfu.zvucnici i slicne periferije nisu potrebne
#22 |
P.E.B.K.A.C.
Postovi: 2,304
#23 |
fanATIčni AMDovac
Lokacija: KC-ZG
Postovi: 1,312
@Gjurovski Hvala na prijedlogu.mene ovdje muci maticna.ima jos prostora pa sam htio pitati da li ima koji bolji model ili je to ok? Ne kuzim se u intel maticne pa pitam... I jos jedna stvar. Ne bi bilo bolje uzeti 2x250gb pa staviti u raid?
#24 |
P.E.B.K.A.C.
Postovi: 2,304
Osobno ja nevidim problem u maticnoj, odradit ce ona svoj posao i vise nego dobro, takoder pocetkom sljedece godine dolaze nove maticne, sa novim socketima novim procesorima i osobno nevim neku korist ulupavanja 1400 kuna u maticnu pogotovo ako kolega nemisli clockati... No opet kada bi drobio toliku lovu ovo bi uzeo: http://www.ve-mil.hr/opis.aspx?prika...&Sifra=1010132 Iskljucivo jer podrzava dvije graficke sa max propusnoscu od 16x sto ga je moguce nakon pola godine za sicu uzeti jos jednu istu grafu i bubnuti u CF a i daje dosta dobre oc mogucnosti kako bi iz eventualnoga CF izvukao max.. No opet bi trebalo i onda jace napajanje uz to... Sto se tice samoga raid-a neznam koliko je to potrebno tebi ili tvom prijatelju osobno mi nije bilo nikada prijepotrebno da ga imam pa niti sa nekom velikom sigurnoscu mogu reci koliko je bolje... za vise informacija imas i takav podforum pa pogledaj koje su hardove najcesce koristili kolika je prednost u brzini naspram jednoga od 500gb... ukratko nemogu ti tu puno pomoci... Tu ces naci sve o hardovima itd: http://forum.pcekspert.com/forumdisplay.php?f=32
#25 |
Postovi: 18
Konfa za Gaming i obrada fotki videa i rad u CS3 do 11000 KN
treba mi konfa za Gaming i obradu Fotki videa i rad u cs3 samo Kutija bez Monitora Tipkovnice i misa do 10000 Kuna ja sam ovako nesto zamisljao pa molim malo za pomoc MBO DFI, s. 775, LAN PARTY UT, X48-T2R, Intel X48, BUS 1600 MHz, serial ATA II, RAID, 7.1 zvuk, DDR 2, 1Gbps, FireWire, ATX 2 1840.- Intel® Core(TM) 2 Quad Q9550 2.83 GHz, 1333MHz, 12MB Cache, LGA775 (QUAD CORE), BOX 2229,- DDR2 4Gb (2x2Gb) PC8500 Corsair,1066MHz,TWIN2X4096-8500C5DF Airf 950.- VGA Ati Radeon HD 4870 X2, 2Gb GDDR5 2x256bit, Dual DVI, PCI Ex 3299.- HDD SAMSUNG SpinPoint F1 750GB 7200rpm 32MB cache Serial ATA II 689.- Napajanje CORSAIR 750W, TX Series CMPSU-750TXEU, 12cm vent,ATX2 920.- DVD upisivač Pioneer DVR-216DBK, DVD±RW, 20x DVD±R ,10x DL 190.- ANTEC P182 EU (gun metal-crno, bez napajanja, vanjsko upravljanj 1099.- jel to ok ili sta bi vi zamjenili ili ako se moze nesto bolje slozit a za manje love ![]() ![]() |
#26 |
Postovi: 1,450
Sve 5, jedino možda da uzmeš jeftiniju ploču.Al ovako iskreno sve komponente koje si stavio su bacanje para.. |
#27 |
Postovi: 18
pa daj onda prjedlog za nesto a ne samo da je bacanje para. Gle nemislim komp mjenjati za 2 godine tako da sam zato i isao na davanje tolko para. ako imas kakav prijedlog slusam drage volje i poslusat cu svaki prjedlog koji mi date ovdje zato sam se i logirao ovdje da nekupujem bezveze bez da cujem misljenja i prijedloge |
#28 |
Postovi: 1,450
CPU:Intel Q6600 MB:Asus P5Q Deluxe RAM:2x2Gb MUSHKIN XP 1066Mhz VGA:SAPPHIRE HD4870X2 HDD:SAMSUNG SpinPoint F1 750GB PSU:CORSAIR HX 620W ... |
#29 |
Postovi: 33,977
Koji q će mu 4870X2 kad je i obična (i 2x jeftinija) 4870 dovoljna? A napajanje je teški overkill jer je za nju dovoljan i Corsair 400. Razliku neka uloži u veći ili još jedan mali, ali brzi disk.
#30 |
P.E.B.K.A.C.
Postovi: 2,304
IMHO: Neka kolega odluci sto mu je na prvom mjestu, posao ili gejmanje? Jer ovu 4870x2 stavljati u kombinaciju sa Q na default taktu je bacanje love... Mislim radi ona i sve ali mislim da se gadan boost osjeca u broju frejmova sa nekim E8400 na 3.8Ghz nego sa Q na 2.4ghz (bar sto se tice FPS-a, za strategije je ionako dovoljno nekih 30-35fps-a za glatko igranje).... Ja sam osobno osjetio na svojoj 8800GTX nekakv boost od 15% sa 2.33Ghz na 3.5Ghz onda si mogu misliti sto ova zvjer radi.... Edit: prestiglo me najbrze pero ovoga foruma ![]() Ako je posao u pitanju onda Q proc i obicna 4870, ako je gejmanje na prvom mjestu onda 4870x2 i E8400 ili E8500.... ![]()
