Postovi: 62
XP - problem
Dakle, pokusavam pokrenuti windowse i kod pokretanja mi se javlja poruka: sorry we apologize for the inconvenience, but windows did not start successfully. a recent hardvere... pa mi ponudi ulazak u safe mode, safe mode with networking, s.m. with com. prompt... Pokusavao sam uci u safe mode, ali niti u njega nemogu uci. Sto god napravio ne mogu uci u windowse jer mi restarta komp pri podizanju os-a. Help!!! P.S. javlja mi se i "Windows could not start because the following file is missing or corrupt: <Windows root>\system32\hal.dll." |
#2 | |
Postovi: 12,613
N00B
Postovi: 3,886
Ne moze bootat jer hal.dll sadrži kod koji povezuje operativni sustav Windows sa hardverom računala,i kako je corrupt boot ne moze dalje.. Jesi provao ovo.. 1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the "R" key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. 4. Typically this will be #1 5. Type "bootcfg /list" to show the current entries in the BOOT.INI file 6. Type "bootcfg /rebuild" to repair it 7. Take out the CD ROM and type "exit" If that doesn't work just press restart button on your PC. Ili ako to ne ide baci oko na ovaj post tu http://forum.pcekspert.com/showpost....09&postcount=2 EDIT:Nino brzi od mene ![]() |
Postovi: 62
Hvala! Buraz mi je rijesio problem sa HIREN BootCD programom. Pozz! |
Lokacija: Ivanić_Grad
Postovi: 2,013
