Staro 01.06.2008., 12:22   #1
lobo64
lobo64's Avatar
Postovi: 1,346
moj prvi htpc
pozdrav svima
opteron1212@2800,tt big typhoon sa x-silence fan koji ispuhuje van,gigabyte ga-ma69g-s3h fsb 280 sa modded zalman nb i sb coolers,2x2 gb supertalent ddr2 800@935 sa scythe ram coolers,chieftec450w sa x-silence fan,samsung t166 320 gb,lg gsa30 dvd-rw,avermedia avertv duo hybrid pci-e dvb tuner,kućište silverstone gd01-mxr dampirano 4 mm gumiranom spužvom,xp pro sp 2,sage tv,avermedia center,imon hd.
temp. u kućištu:hdd 38,mb 30-45,cpu 35-48.
trošak:cca 5k kn,ne računajući rad.
slike
http://www.imagesforme.com/show.php/...0052008014.jpg
http://www.imagesforme.com/show.php/...0052008013.jpg
http://www.imagesforme.com/show.php/...0052008012.jpg
http://www.imagesforme.com/show.php/...0052008011.jpg
http://www.imagesforme.com/show.php/...0052008010.jpg
http://www.imagesforme.com/show.php/...0052008009.jpg
http://www.imagesforme.com/show.php/...0052008008.jpg
http://www.imagesforme.com/show.php/...0052008007.jpg
http://www.imagesforme.com/show.php/...0052008006.jpg
http://www.imagesforme.com/show.php/...0052008005.jpg
http://www.imagesforme.com/show.php/...0052008004.jpg
http://www.imagesforme.com/show.php/...0052008003.jpg
http://www.imagesforme.com/show.php/...0052008002.jpg
http://www.imagesforme.com/show.php/...0052008001.jpg
http://www.imagesforme.com/show.php/...2052008004.jpg
http://www.imagesforme.com/show.php/...2052008003.jpg
http://www.imagesforme.com/show.php/...8052008006.jpg
http://www.imagesforme.com/show.php/...8052008005.jpg
http://www.imagesforme.com/show.php/...8052008004.jpg
http://www.imagesforme.com/show.php/...8052008003.jpg
http://www.imagesforme.com/show.php/...2052008002.jpg
http://www.imagesforme.com/show.php/...2052008001.jpg
http://www.imagesforme.com/show.php/73886_22052008.jpg
ok,spužvu sam spomenuo.nakon što sam stripao kućište primjetio sam da je napravljeno od tankog lima (cca. 3kg teško),te samim time loše kvalitete.spojeve limova (mehaničke,zakovice i vijci) sam cijelom dužinom zalio gel brzim ljepilom,iznutra i izvana nakon čega je kućište dobilo na torzionoj čvrstoći.na ispupčenja koja nose napajanje sam nalijepio teflonske trake kao izolatore vibracija.na samo napajanje ja stavljen silikonski okvir prema kućištu.iste teflonske trake su zaljepljene na vodilice hdd kaveza.svi ventovi u kućištu,kao i onaj na napajanju su također na silikonskim okvirima.na cijelu donju stranu kućišta (izvana) sam zaljepio 3mm umjetnu kožu (nije slikano).na poklopcu je dremelom izrezana rupa veličine 120 mm venta,u milimetar točno iznad proc hladnjaka (plast.mrežica je još crna,biti će obojana u boju kućišta).
sa prednje strane(ispred kaveza za hdd) montirana je minebea 92mm 1200 rpm koja upuhuje,sa stražnje strane je noiseblocker 80mm 1150 rpm koji isto tako upuhuje(sa usisne strane izvana je perivi filter) preko usmjerivača(napravljenog od blister pakiranja jednog 80 mm venta) direktno na tranzistore napajanja na ploči.
na mb-u je na sve tranzistore napajanja(cpu,ram,nb,sb) term. ljepilom zaljepljeno 12 hladnjaka na mjeru izrezanih iz pasivnog hlađenja jedne stare grafičke.
na napajanju sam odrezao(skratio) dvije grane moleksa zbog gužve u kućištu(na odrezan kraj grane sam sa svake strane stavio molekse tako da se kablovi ponovo mogu koristiti po potrebi).
4 pin 12v za ploču je produžen i položen ispod mb-a.
na tv karticu je na phillipsov čip zaljepljen nb pasivnjak,dva ram čipa su isto dobila pasivnjake.
sve opisano se iz fotki jako slabo(ili uopće ne) vidi.
Zadnje izmijenjeno od: lobo64. 04.06.2008. u 21:34. Razlog: dodano
lobo64 je online   Reply With Quote
Staro 01.06.2008., 12:26   #2
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Galerija ti ne šljaka
Staro 03.06.2008., 08:06   #3
Killer_99
Ubojito stvorenje
Datum registracije: Apr 2008
Lokacija: Irland
Postovi: 97
Ljepo sve to, ali daj navedi kaj si sve modal?
Mislim neznam kaj bi to trebal gledati, tvoj kupljeni htpc ili kaj si radil na njemu
Im here to kill You
Killer_99 je offline   Reply With Quote
Staro 03.06.2008., 20:25   #4
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,007
Autor Killer_99 Pregled postova
Autor lobo64 Pregled postova
...dampirano 4 mm gumiranom spužvom...
Valjda je na to mislio.
I daj molim te koristi thumbove.
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
