Staro 20.05.2008., 15:38   #1
Rokas
Rokas's Avatar
Postovi: 64
ASUS Eee PC 900/901 vs. MSI Wind
MSI Wind dostupan u pre-orderu http://eeepc.net/msi-wind-now-availa...t-expansyscom/
$399 Linux version:
10 inch 1024 x 600 screen
1.6Ghz Atom with 512MB RAM
80GB HDD
3 cell battery / 2.5 hrs
1.2 kg 260 mm x 180 mmm x 31 mm
Novel’s SUSE Linux
$549 XP version:
1.6Ghz Atom with 1GB RAM
80GB HDD
Bluetooth
6 cell battery / 5.5 hrs
1.3 kg 260 mm x 180 mmm x 31 mm
XP Home
Four different colors, including black, white, silver, and pink.
Takodjer još jedna zanimljiva kombinacija (post sa msi-evog foruma)...
"I confirm the Tuoppi's speculation. I have contacted the GNT (Distributor) store that that sells these winds. The store has contacted the distributor which has confirmed so far that the Finnish versions are:
10" Led LCD WSVGA 1024x600
Intel Atom 1.6GHz (Atom Z530, Hyperthreading SMT)
Intel GMA950
1024Mb PC2-5300
80Gb
WLAN 802.11a/b/g - Bluetooth - Webcam 1,3mb - 3 x USB 2.0 - 6-cell battery- Black - Warranty 24month
260 x 180 x 19-31.5mm
Linux (most likely Suse) 410€
Windows XP home (custom?) 432€
So the only difference is xp for 20€."
Ako Asus ne spusti cijenu EEEja....odoh MSI-u.....
Nda...i stiže prije..bar je tako najavljeno...
Rollin' on... Intel Core 2 Duo E6750~Gigabyte GA-P35C-DS3R ~OCZ 2GB 800 Mhz Gold~Gigabyte 8800 GTS 640MB~Logitech G9
...und...
MSI Wind UMPC black
Ridin' on...Optima 10Mbps FLAt or W'n'W 7.2 Mbps
Rokas je offline   Reply With Quote
Staro 20.05.2008., 15:55   #2
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Samo da nebude "hrvatska informatička formula" za preračunavanje cjene ($x10=HRK) jer za 4000kn ima i boljih laptopa...
Have a nice day...
Staro 20.05.2008., 18:47   #3
Rokas
Rokas's Avatar
Postovi: 64
Autor yedwy Pregled postova
Mislim da neće bit velikih odstupanja od cijene...za Eee 700 bar nije bilo...
Bitno da je Asus sada dobio dobranog rivala...koi ga čak u mnogo tome šiša...jedino mi je disk kod msi-a upitan...tj. koliko je sporiji u odnosu na ssd drive...
za ostalo:10" display,bt,atom,6 cell bateriju, te funkcionalniju tipkovnicu više sam nego spreman izdvojiti deklariranu svotu,čak me ni onih +200dkg ne zamara previše
...und...
MSI Wind UMPC black
Staro 20.05.2008., 18:49   #4
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Samo nek se oni međusobno kače s cijenama..bolje za nas.. Još da puste "Vjetar" prije Asusa..možda EEE pojeftini
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline   Reply With Quote
Staro 22.05.2008., 12:21   #5
Rokas
Rokas's Avatar
Postovi: 64
Exclamation
Prema http://www.liliputing.com/ u Europu MSI WInd stiže sredinom 7-og mj. i to sa cijenom od 300€ ...jedina je zamjerka što će se isti modeli isporučivati sa baterijama od 3 ćelije (2.5-3 sata)
...und...
MSI Wind UMPC black
Staro 22.05.2008., 12:31   #6
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
Vrlo fini laptop... taman dimenzija.
EEE mi je nekako premalen i neugodan za dulje korištenje dok je ovaj MSI Wind vrlo pristojno računalo s odličnim procesorom.
- Barney Stinson
Staro 24.05.2008., 21:48   #7
SilentException
SilentException's Avatar
Lokacija: RI-KR
Postovi: 789
dobra je wind stvarcica, iako se meni vise svidja eee
jel ima koji od ovih ultramegaportabilaca / eee klonova firewire? ili neku mogucnost prosirenja pa da sam stavim fw karticu?
SilentException je offline   Reply With Quote
Staro 25.05.2008., 02:57   #8
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Autor SilentException Pregled postova
Misliš obrađivati video na tome?
Staro 30.05.2008., 18:01   #9
Rokas
Rokas's Avatar
Postovi: 64
Thumbs up
Evo full recenzije za Wind......bolji je od Asusa u svim pogledima
http://forums.msiwind.net/general-di...ample-t25.html
...und...
MSI Wind UMPC black
Staro 31.05.2008., 00:35   #10
hislipanj
Postovi: 62
mislim da neću moć odoljeti windu ako kod nas bude oko 300€...zbilja super izgleda (i izgledom i cijenom i konfiguracijom...)
hislipanj je offline   Reply With Quote
Staro 31.05.2008., 00:52   #11
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
Wind izgleda obećavajuće, ako budu ti specsi i ta cijena bude pomel EEE-a...
potemkin.hr je offline   Reply With Quote
Staro 31.05.2008., 01:14   #12
kundak
kundak's Avatar
Postovi: 388
ima li wind mogucnost solid state hdd. Ne triba mi ovih 80gb, bitnija mi je otpornost na razbijanje
kundak je offline   Reply With Quote
Staro 31.05.2008., 01:26   #13
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Autor kundak Pregled postova
Nama leecherima na faksu je bitan i prostor, iako bi mogao preživjeti i s SSDom jer imam prijenosni WD
Staro 31.05.2008., 07:34   #14
Postovi: 34,006
Bit će tu raznih cijena i moglo bi se dogoditi da XP verzija bude i zericu preskupa, iako se dobije više rama, jača baterija i BT.
http://www.engadget.com/2008/05/13/m...or-the-us-399/
Staro 31.05.2008., 10:07   #15
Rokas
Rokas's Avatar
Postovi: 64
Može se zamijeniti sa SSD-om bez beda...
..btw...evo i novih dizajna ...
...und...
MSI Wind UMPC black
Staro 31.05.2008., 22:09   #16
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,824
Ček kaj taj atom proc to je dual core?il sam ja to krivo videl na onom linku....Sve u svemu ovaj MSI je zvijer,i još ak bu bil povoljniji od asus-a,ovo bi moglo bit sljedeče ulaganje
Staro 31.05.2008., 22:29   #17
lordVerdranius
Postovi: 310
Autor zvonac Pregled postova
Hm, koliko ti ja znam, Atom je najmanji Intelov processor, i za sada koliko sam vidio nisu napravili dual core verziju Atoma, je da se najavljuje...
lordVerdranius je offline   Reply With Quote
Staro 01.06.2008., 11:45   #18
Rokas
Rokas's Avatar
Postovi: 64
"Diamondville has 1 core but 2 threads. So we might expect the MSI Wind to perform better while multitasking as compared to the Eee PC. It also seems to have Speedstep, which lowers the clock speed of the processor when idle. This might further help to conserve battery life"
Atom Dual Korci su tek u najavi...
http://www.engadget.com/2008/05/26/r...t-fleshed-out/
...und...
MSI Wind UMPC black
Staro 01.06.2008., 12:40   #19
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
Vjerojatno neka forma Hyperthreadinga iz ere P4
- Barney Stinson
Staro 01.06.2008., 12:54   #20
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ja cu sigurno uzeti ovoga sa 6cel baterijom jer mi je malo 3h inace wind je taman po mojoj mjeri dovoljno mali a opet dovoljno veliki
.i.
Razer Blade 15
Staro 01.06.2008., 13:47   #21
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Meni je presuđujući faktor autonomija tj. baterija.
Ne očekujem nikakve performanse niti ih trebam, već mali lap za net kojemu baterija traje pun kupus.
Staro 02.06.2008., 10:34   #22
Rokas
Rokas's Avatar
Postovi: 64
Evo još par recenziji,svakim danom je sve dostupniji...
First Look: MSI Wind - TrustedReviews
http://www.trustedreviews.com/notebo...ok-MSI-Wind/p1
Crave
http://crave.cnet.co.uk/laptops/0,39...9297131,00.htm
...und...
MSI Wind UMPC black
Staro 02.06.2008., 11:05   #23
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Mislim da ovo nije ni klasa sa ee, ovo izgleda ko normalni laptop i takve su komponete dok ee j ekao igračka.
Ja sam za ako će cijene bit 300E
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 02.06.2008., 12:25   #24
Rokas
Rokas's Avatar
Postovi: 64
Autor Mortal Pregled postova
Eee i Wind su ista klasa....subnotebook/umpc...
btw...uputih mail Renoprom-u,koji je zastupnik za MSI...svezi Winda,evo odgovora,gotovo se sve zna osim cijene.....
WIND NB. Model koji ce biti u prodaji je 10” LCD display, atom platform, 1Gb DDR2, 80 GB hard drive, WLAN, bluetooth, webcam, 3 cell battery, XP OS
Krajem 6. mjeseca će možda biti za isporuku, nismo još dobili točan datum dolaska I za par dana bi trebali saznati MPC.
Lijep pozdrav,
...und...
MSI Wind UMPC black
Staro 02.06.2008., 13:24   #25
Demon Hunter
Postovi: 999
Eee je kod nas preko 300€, tako da budi siguran da će i Wind biti
Demon Hunter je offline   Reply With Quote
Staro 02.06.2008., 13:36   #26
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Po meni je jedna od najvaznijih stavki EEE-a bilo to sto je bio izdrzljiv....
Gledajuci filmice na Yo-bi-tou kako ga ekipa baca sa metar i pol, stavlja upaljenoga u mikrovalnu itd... cak mi je i kompic jedan zaspao na njemu probudio se i radi....
Bas me zanima koliko je taj Wind spreman podnijeti, posto ima ugraden hard mislim da ne puno...
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 02.06.2008., 15:56   #27
Postovi: 34,006
Staro 04.06.2008., 10:21   #28
Router
Hejter
Postovi: 6,521
Vidim da se tu gore u temi spominju neke druge cijene Winda , ovo su valjda sluzbene ako pise da je pusten ...
http://www.bug.hr/vijesti/index.asp?id=87846
Staro 05.06.2008., 08:46   #29
Postovi: 34,006
Staro 05.06.2008., 19:40   #30
Rokas
Rokas's Avatar
Postovi: 64
Dostupan u
U.S. - 16.06
U.K. - 23.06 (vjerojatno i kod nas oko tog datuma)
fora video
http://www.youtube.com/watch?v=qGweeoJP0Wg
PIC Gallery
http://www.flickr.com/photos/26516955@N07/
..i jedna zanimljiva slika
...und...
MSI Wind UMPC black
Zadnje izmijenjeno od: Rokas. 05.06.2008. u 20:05.
