Postovi: 64
ASUS Eee PC 900/901 vs. MSI Wind
MSI Wind dostupan u pre-orderu http://eeepc.net/msi-wind-now-availa...t-expansyscom/ ![]() $399 Linux version: 10 inch 1024 x 600 screen 1.6Ghz Atom with 512MB RAM 80GB HDD 3 cell battery / 2.5 hrs 1.2 kg 260 mm x 180 mmm x 31 mm Novel’s SUSE Linux ![]() $549 XP version: 10 inch 1024 x 600 screen 1.6Ghz Atom with 1GB RAM 80GB HDD Bluetooth 6 cell battery / 5.5 hrs 1.3 kg 260 mm x 180 mmm x 31 mm XP Home Four different colors, including black, white, silver, and pink. Takodjer još jedna zanimljiva kombinacija (post sa msi-evog foruma)... "I confirm the Tuoppi's speculation. I have contacted the GNT (Distributor) store that that sells these winds. The store has contacted the distributor which has confirmed so far that the Finnish versions are: 10" Led LCD WSVGA 1024x600 Intel Atom 1.6GHz (Atom Z530, Hyperthreading SMT) Intel GMA950 1024Mb PC2-5300 80Gb WLAN 802.11a/b/g - Bluetooth - Webcam 1,3mb - 3 x USB 2.0 - 6-cell battery- Black - Warranty 24month 260 x 180 x 19-31.5mm Linux (most likely Suse) 410€ Windows XP home (custom?) 432€ So the only difference is xp for 20€." Ako Asus ne spusti cijenu EEEja....odoh MSI-u..... ![]() Nda...i stiže prije..bar je tako najavljeno...
Rollin' on... Intel Core 2 Duo E6750~Gigabyte GA-P35C-DS3R ~OCZ 2GB 800 Mhz Gold~Gigabyte 8800 GTS 640MB~Logitech G9 ...und... MSI Wind UMPC black Ridin' on...Optima 10Mbps FLAt or W'n'W 7.2 Mbps |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Samo da nebude "hrvatska informatička formula" za preračunavanje cjene ($x10=HRK) jer za 4000kn ima i boljih laptopa... ![]()
-- Have a nice day... |
#3 | |
Postovi: 64
Mislim da neće bit velikih odstupanja od cijene...za Eee 700 bar nije bilo... Bitno da je Asus sada dobio dobranog rivala...koi ga čak u mnogo tome šiša...jedino mi je disk kod msi-a upitan...tj. koliko je sporiji u odnosu na ssd drive... za ostalo:10" display,bt,atom,6 cell bateriju, te funkcionalniju tipkovnicu više sam nego spreman izdvojiti deklariranu svotu,čak me ni onih +200dkg ne zamara previše ![]()
..dno
Lokacija: Crikvenica
Postovi: 1,973
Samo nek se oni međusobno kače s cijenama..bolje za nas.. Još da puste "Vjetar" prije Asusa..možda EEE pojeftini ![]()
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.” |
Postovi: 64
![]() Prema http://www.liliputing.com/ u Europu MSI WInd stiže sredinom 7-og mj. i to sa cijenom od 300€ ![]()
Suit up!
Postovi: 5,967
Vrlo fini laptop... taman dimenzija. EEE mi je nekako premalen i neugodan za dulje korištenje dok je ovaj MSI Wind vrlo pristojno računalo s odličnim procesorom.
..dno
Postovi: 1,973
Postovi: 64
![]() Evo full recenzije za Wind......bolji je od Asusa u svim pogledima ![]() http://forums.msiwind.net/general-di...ample-t25.html ![]()
Postovi: 62
mislim da neću moć odoljeti windu ako kod nas bude oko 300€...zbilja super izgleda (i izgledom i cijenom i konfiguracijom...) |
Postovi: 388
ima li wind mogucnost solid state hdd. Ne triba mi ovih 80gb, bitnija mi je otpornost na razbijanje ![]() |
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Postovi: 33,959
Bit će tu raznih cijena i moglo bi se dogoditi da XP verzija bude i zericu preskupa, iako se dobije više rama, jača baterija i BT. http://www.engadget.com/2008/05/13/m...or-the-us-399/
Postovi: 64
#17 |
Postovi: 310
Hm, koliko ti ja znam, Atom je najmanji Intelov processor, i za sada koliko sam vidio nisu napravili dual core verziju Atoma, je da se najavljuje... |
#18 | |
Postovi: 64
"Diamondville has 1 core but 2 threads. So we might expect the MSI Wind to perform better while multitasking as compared to the Eee PC. It also seems to have Speedstep, which lowers the clock speed of the processor when idle. This might further help to conserve battery life" Atom Dual Korci su tek u najavi... http://www.engadget.com/2008/05/26/r...t-fleshed-out/
#20 |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ja cu sigurno uzeti ovoga sa 6cel baterijom jer mi je malo 3h ![]() ![]()
#21 |
..dno
Postovi: 1,973
Meni je presuđujući faktor autonomija tj. baterija. Ne očekujem nikakve performanse niti ih trebam, već mali lap za net kojemu baterija traje pun kupus.
#22 |
Postovi: 64
Evo još par recenziji,svakim danom je sve dostupniji... First Look: MSI Wind - TrustedReviews http://www.trustedreviews.com/notebo...ok-MSI-Wind/p1 Crave http://crave.cnet.co.uk/laptops/0,39...9297131,00.htm
#24 | |
Postovi: 64
Eee i Wind su ista klasa....subnotebook/umpc... btw...uputih mail Renoprom-u,koji je zastupnik za MSI...svezi Winda,evo odgovora,gotovo se sve zna osim cijene..... WIND NB. Model koji ce biti u prodaji je 10” LCD display, atom platform, 1Gb DDR2, 80 GB hard drive, WLAN, bluetooth, webcam, 3 cell battery, XP OS Krajem 6. mjeseca će možda biti za isporuku, nismo još dobili točan datum dolaska I za par dana bi trebali saznati MPC. Lijep pozdrav,
#25 |
Postovi: 999
#26 |
P.E.B.K.A.C.
Postovi: 2,304
Po meni je jedna od najvaznijih stavki EEE-a bilo to sto je bio izdrzljiv.... Gledajuci filmice na Yo-bi-tou kako ga ekipa baca sa metar i pol, stavlja upaljenoga u mikrovalnu itd... cak mi je i kompic jedan zaspao na njemu probudio se i radi.... Bas me zanima koliko je taj Wind spreman podnijeti, posto ima ugraden hard mislim da ne puno...
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/ Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
#27 |
Postovi: 33,959
Stiže i konkurenija u vidu Acera i Della. http://www.engadget.com/2008/05/29/f...e-eee-pc-twin/ http://gizmodo.com/393815/exclusive-dell-mini-inspiron-their-first-mini-laptop EDIT: Fudo se dočepao Winda i napravio test http://www.fudzilla.com/index.php?op...7613&Itemid=40
#28 |
Hejter
Postovi: 6,521
Vidim da se tu gore u temi spominju neke druge cijene Winda , ovo su valjda sluzbene ako pise da je pusten ... http://www.bug.hr/vijesti/index.asp?id=87846 |
#29 |
Postovi: 33,959
Evo ti ga na tal. eBayu, i za prednarudžbu http://cgi.ebay.it/NOTEBOOK-MSI-WIND...mZ380027102313 http://www.fotodigit.it/scheda_prodo...ROD_29379.html
#30 |
Postovi: 64
Dostupan u U.S. - 16.06 U.K. - 23.06 (vjerojatno i kod nas oko tog datuma) fora video http://www.youtube.com/watch?v=qGweeoJP0Wg PIC Gallery http://www.flickr.com/photos/26516955@N07/ ..i jedna zanimljiva slika ![]() ![]()
Rollin' on... Intel Core 2 Duo E6750~Gigabyte GA-P35C-DS3R ~OCZ 2GB 800 Mhz Gold~Gigabyte 8800 GTS 640MB~Logitech G9 ...und... MSI Wind UMPC black Ridin' on...Optima 10Mbps FLAt or W'n'W 7.2 Mbps Zadnje izmijenjeno od: Rokas. 05.06.2008. u 19:05. |
