Staro 02.05.2008., 23:22   #1171
bozzomfeeder
bozzomfeeder's Avatar
Lokacija: Sinj
Postovi: 1,080
Da ne otvaram sad novu temu primjetih da je ta Gigabytica a i ova Twintech dosta skraćena, skoro ko stara 7600GT, ima li to kakvog utjecaja, tj na čemu se je to "uštedilo"...?
bozzomfeeder je offline   Reply With Quote
Staro 02.05.2008., 23:28   #1172
Igorr
Flajing super šiiiip
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,686
Nije se "štedilo" na nicemu (barem kod gigabyta), stovise, dijelovi su joj radeni i kvalitetnije nego kod drugih 8800GT:
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics cards now feature a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
A to sto je kraca je super, jer ti zauzima osjetno manje mjesta, meni je super jer lakse dolazim do svojih sata prikljucaka
5.1.4 setup:
Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE
Amps - Marantz Cinema 40 + ROTEL RMB-1585
Igorr je offline   Reply With Quote
Staro 02.05.2008., 23:31   #1173
maX
maX's Avatar
Postovi: 7,326
Autor Igorr Pregled postova
ista stvar i kod mene, ogroman kamen mi je pao sa srca kad sam vidio kako je grafa kratka
Staro 03.05.2008., 07:40   #1174
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Molim te reci mi da si se samo šalio...
Have a nice day...
Staro 03.05.2008., 09:29   #1175
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,311
Evo ti jedan LOLek za ovu izjavu.
Staro 03.05.2008., 11:31   #1176
Igorr
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,686
Autor yedwy Pregled postova
Autor Gilbert5 Pregled postova
Aj malo objasnite
Argumentirajte po cemu je to sto sam napisao krivo...
5.1.4 setup:
Staro 03.05.2008., 13:10   #1177
Gordon Freeman
Datum registracije: Mar 2008
Postovi: 290
po mom mišljenju ova 8800GT gigabyte [ujedno koju i ja imam ] je najsiplativija 8800GT gledam okolo clockove i niti jedni neidu kao ova 8800GT..gledam i temprerature okolo i niti jedan stock cooler nehladi tako dobro......cijena je isto super....
Gordon Freeman je offline   Reply With Quote
Staro 03.05.2008., 13:45   #1178
Baja 001
Baja 001's Avatar
Postovi: 7,504
Aj malo objasnite
Pa to je zato što taj "Ultra Durable" je više marketinški trik nego toliko korisna stvar. Nije da nema koristi od toga, nego jednostavno izgleda puno bolje, ali je u stvari malo.
Što se mene tiče volim vidit solid kondenzatore, nego one debeljuce stare. I naravno zato yedwy je odgovorio ovako:
Staro 03.05.2008., 14:06   #1179
yedwy
yedwy's Avatar
Postovi: 6,956
Aj malo objasnite
Zato jer navođenje pamfleta nije nikav argument...
Evo ti npr samo dvije stvari...
Tvoja ima kolko ono 2g garancije?
Vidiš moja MSI ima 3g a ja MSI ne smatram nekom markom...
Sad ide reznon - Gigabyte zna da je napravio tako dobru karticu da tebi netreba 3g garancije jer neće crknuti, zapravo tebi garancija uopće i netreba to je samo za ukras s takvom uber karticom jelda...
Inače Gainward daje isto 3g (iako kod nas uvoznici židove i daju samo 1g to je naš hr problem) i Albatron i još poneke firme...
A propo SCa...
http://global.msi.com.tw/index.php?f...maincat_no=130
Baci malo pogled na prvi stavak pod features...
Zapravo kad razmislim unatrag, na svim highend nvidia grafama koje sam imao u zadnjih 3-4g (a bilo ih je nekoliko) sam IIRC imao isključivo SCe tako da brijem da su dio nvidijine osnovne specifikacije i bilo bi jako tragično kad bi ih neko mjenjao jer uostalom oni su na tom grafama opravdani - radi toga jer su a) trajniji, b) manje osjetljivi na grijanje, c) manje veličine pa stanu pod ta brutus coolere koji sve živo pokrivaju...
Tako da ti lagano izjava ne stoji, o isplativosti neću komentirati jer nije prednmet moje reakcije, lako moguće da stvarno i je najisplativija i sve ali "karica na kojoj se nikako nije štedilo i djelovi su i kvalitetniji nego na drugima" e to baš nebi išlo...
Have a nice day...
Staro 03.05.2008., 14:41   #1180
Igorr
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,686
Glede garancije - bio sam uvjeren da imam 3 godine, ali trenutno nemogu tvrditi jer nemam račun kod sebe a ovi idioti nisu na stranicama stavili informaciju o trajanju doticne. Ali u svakom slucaju:
U ovom tvom "argumentiranju" pise dosta nepotrebnih i suvisnih stvari kojima si naglasavao gluposti. Ne vidim smisao nekih recenica.
"Sad ide reznon - Gigabyte zna da je napravio tako dobru karticu da tebi netreba 3g garancije jer neće crknuti, zapravo tebi garancija uopće i netreba to je samo za ukras s takvom uber karticom jelda."
Nepotreban i glup sarkazam.
I slijedi moje pitanje: navedi mi konkretno, na cemu su stedjeli pri skracivanju kartice (kad tvrdis da su stedili)?
5.1.4 setup:
Staro 03.05.2008., 14:59   #1181
yedwy
yedwy's Avatar
Postovi: 6,956
Ne ja ne tvrdim da su štedili nego me asmetala tvoja izjava "dijelovi su joj radeni i kvalitetnije nego kod drugih 8800GT" jer to nije istina i EOD oko toga, nije niti kvalitetnija niti nekvalitetnija od ostalih, isti je drek ko i sve druge... Jasno sad na što je ciljano?
Inače di god vidim Gigabyte ima 24mj kao i za ploče prema tome sumnjam da ti imaš 3g ali nikad ne reci nikad...
Have a nice day...
Staro 03.05.2008., 15:10   #1182
Igorr
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,686
Moja greska je sto sam izostavio rijec "NEKIH", dakle htio sam reci sljedece: "Nisu stedjeli na komponentama, stovise, djelovi su im kvalitetniji nego kod NEKIH drugih proizvodaca".
A recenica se trebala interpretirati na nacin da ova 8800GT definitivno nije nekvalitetnija od drugih proizvodaca... Sto je bila i jedina svrha mog posta.
5.1.4 setup:
Staro 03.05.2008., 15:12   #1183
Razer
Razer's Avatar
Postovi: 11,642
Dotična konstatacija nije niti bila potrebna, jer nitko nije ni tvrdio da je nekvalitetna
Staro 03.05.2008., 15:14   #1184
Igorr
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,686
Autor bozzomfeeder Pregled postova
Zbog ovoga je bila potrebna. Covjeka je zanimalo i ja sam odgovorio...
5.1.4 setup:
Staro 03.05.2008., 15:51   #1185
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Autor Ice Demon Pregled postova
Zanimljivo mi je samo kako moja uspije radit na 2100MHz meme, gledam da nema baš puno ljudi tako.
Meni mema ide do 2360 bez vmoda a sa njim neznam, i ne zahebavam se. Gpu do 760 (mislim da je bilo 754) a za shadere neznam njih nisam testiroao.
Meni se potrefilo, ubo sam dobru kartu, više odlicnu
NovA Squadron
kripton je offline   Reply With Quote
Staro 03.05.2008., 15:56   #1186
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,735
Autor Gordon Freeman Pregled postova
ma koči i mene i ja to i osjetim u igrama nekad.
Hamm je online   Reply With Quote
Staro 03.05.2008., 16:38   #1187
Razer
Razer's Avatar
Postovi: 11,642
Hamm je pod dojmom nove P1-ice
Staro 03.05.2008., 17:30   #1188
žile
žile's Avatar
Postovi: 3,074
Kako je ovo dobro.Eto gordone,ja imam to čemu ti težiš,i vjeruj mi da ni na koji način nećeš osjetit prelaz sa 2 na 6MB L2,kao što nisam ni ja osjetio.Doduše možeš me pitat zašto sam to napravio,razlog je jednostavan,ja bi bio overkluoker i po cijele dane,osim da gledam igre kako mi ubitačno štekaju na rezi od 1440x900,žicam razera da me doda na svoju msn listu da mogu overkluokirat š njime.
Dobro,tvoja lova,gospodari s njom kako te volja,ali nemoj da mi moramo čitat kako ti igre štekaju na maloj rezi jer znamo da to nemože biti istina,a i sam priznaš tu i tamo da nije.
Moram se malo zaletit do Osijeka do prijateljice i dogovorit se da mi riješi neke đeje/škije/skjame,jer vidim da je u tvom kraju jeeeebeeenaaaaaaaa.
žile je offline   Reply With Quote
Staro 03.05.2008., 18:59   #1189
Shamanix
Shamanix's Avatar
Postovi: 870
Autor žile Pregled postova
Ja sam vec u Osijeku, ja bi isto malo (puno)..
Shamanix je offline   Reply With Quote
Staro 03.05.2008., 23:26   #1190
Moncho
Moncho's Avatar
Lokacija: Sarajevo
Postovi: 45
Mislim da malo pretjerujemo za memu da stabilno radi na toj frekvi na toj karti 8800 GT
Moncho je offline   Reply With Quote
Staro 07.05.2008., 07:36   #1191
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
A da podijelim koju bananu? Obrisao spam, slijedeći put neću samo postove brisati...
Staro 10.05.2008., 12:39   #1192
DanielDJ
DanielDJ's Avatar
Lokacija: Đakovo
Postovi: 250
inace ja imam Gigabyte grafu i garancija je 24 mj. ,a garanciju moš pogledat na kutiji, na ovakvoj naljepnici http://img181.imageshack.us/my.php?i...lika029xz2.jpg
DanielDJ je offline   Reply With Quote
Staro 12.05.2008., 18:42   #1193
Sova_13
Sova_13's Avatar
Datum registracije: Apr 2008
Lokacija: Bjelovar
Postovi: 6
Autor karlito Pregled postova
pa on vjerojatno svog zalmančeka nije nafrljio na max broj okretaja, pa mu je zato nečujan....
Ja imam tu 8800gt sa tim novim zalmanom, max obrtaji, nečujna je, temp idle je oko 40, a load 60-70, nisam kloko jer mi matična sucka (vrlo nestabilno radi)
Susjed prodaje komp u dijelovima: možete ih pogledati po mojoj ulici
Sova_13 je offline   Reply With Quote
Staro 13.05.2008., 11:57   #1194
DuffJP
DuffJP's Avatar
Lokacija: Zgb
Postovi: 100
Evo danas isao u nabavku svoje nove graficke
Prvo sam mislio uzeti 8800GTS 512MB (cije se cijene krecu oko 1600kn-1700kn) jer sam zivio u uvjerenju da su 8800GT od 1400kn pa nadalje, sto je prihvatljiva razlika, pa kao ono kad je bal nek je maskenbal
No onda naletih na ovo: http://www.adm.hr/product_info.php?products_id=5225
Ja ono - dobro mozda je neka greska, ili jednostavno nije dobavljiva. Zvrcnem ljude, i doticni potvrde da ju imaju
Sad da malo pojasnim zasto sam ja toliko odusevljen:
ne samo da za 1200kn dobijete 8800GT sa 512MB nego dobijete jos i zalmana (ne 700-ku nego jos bolji, s kojim moram priznati da sam vise nego zadovoljan, hladi ko blesav i nije ni priblizno bucan koliko ljudi melju po internetu) i Neverwinter Nights 2, odnosno kao da placate karticu valjda nekih 800kn
A jos je i tvornicki overclockana na 700MHz za jezgru i 1840MHz za memoriju (inace su na 600/1800), dobro memorija nije zvijerski overclockana ali frekvencija za jezgru je itekako respektabilna.
Nakon par sati uzivanja u Crysisu (leeeeti na max koliko xp nudi na 1280:1024) odo ja nju malo overclockati
Mic po mic dizem i testiram (2* 3dmark2006 + cca 15miin crysisa), oko 8 sati dodem do 750MHz - jezgra, 1840MHz - shaderi, i 2000MHz - memorija, i prode 3dmark, na sto sam ju odlucio podrobnije testirati u crysisu pa da budem siguran da ona to moze drzati - uglavnom 2h igranja bez prestanka i sve savrseno radi, rock
Nakon ovog vise ne zelim ici, jer obecao sam sam sebi da ako dodem do 750/2000 da cu stati, a posto sam praznovjeran to cu i napraviti
Uglavnom ljudi, moja velika preporuka, za toliko malo para - previse muzike, ovo cudo na ovim frekvencijama je u razini 8800Ultra (sto je najgore mislim da i ne pretjerujem).
svaka cast...a ja ko kreten kupio MSIevu GTicu za 2050
kuna,sa referentnim dizajnom i hladnjakom,kao neka oc verzija,digli takt za 30 megaherca i za to naplatili 500 kuna
drzim ju na 712-720 mhza,al se grije ko vrag
ovo ti je imho best buy te grafe koji si mogao nac
uzivaj!
DuffJP je offline   Reply With Quote
Staro 14.05.2008., 13:32   #1195
NGB
Postovi: 14
Novi Driveri - 175.16 za 8800gt
Imam Gigabyte 8800gt/512Mb, driveri 169.21 (skinuto s NVidia), kako vidim izašli novi driveri 175.16.
Budući da sam 'average user' par pitanja za znalce:
1. Što dobivam instalacijom ovih novih drivera u poboljšanju performansi grafe? Ako ima onih koji ih koriste, neka postaju? (komp. mi je prvenstveno za igre)
2. Kako instalirati nove?, što treba prvo napraviti? - deinstalacija starih, pa instalacija novih, treba li kakav program za čišćenje starih drivera ili ne?, ako da koji?
NGB je offline   Reply With Quote
Staro 14.05.2008., 13:50   #1196
kripton
Cars & Tunning
kripton's Avatar
Postovi: 536
1. Performanse se povecavaju, iako to nemora biti slucaj. Dodavaju se stvari koje povecavaju iskoristivost graficke kartice. Kad vec igras, onda i koristi nove drivere, iako se zna dogoditi da nova serije drivera bude losija od prošle.
2.Možeš deinstalirat, ali i nemoraš.
Edit: Vec ima tema sa novim driverima, trebao si tamo pitat. Možda moderatori mogu spojiti :P
NovA Squadron
Staro 14.05.2008., 22:40   #1197
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
imam ih i ja od jucer i zasad sam primjetio da mi malo drukcije u crysisu loada teksture (odmah ih relativno sve ucita na pocetku ...) sta ja znam mislim da su bolji od starih...
Staro 14.05.2008., 22:44   #1198
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
I ja sam osjetil malo poboljsanje performansa u crysisu tak da preporucam da instaliras nove drivere
Majo je offline   Reply With Quote
Staro 15.05.2008., 08:56   #1199
yedwy
yedwy's Avatar
Postovi: 6,956
Ja imam 174.93 sa Guru3Da skinute već duže vrijeme i zadovoljan sam s njima, nemam namjeru prelazit na ove ako ne ispliva neki jako dobar razlog...
Have a nice day...
Staro 23.05.2008., 10:05   #1200
Verbum
Postovi: 682
Gainward Bliss 8800 GT 512MB PCX TV DD
Nigdje na netu ne mogu naci review doticne grafe pa me zanima da li je netko od clanova foruma ima?
Naravno bio bih zahvalan da se napise par rijeci o doticnoj . Najvise me zanima kako funkcionira to dual slot hadjenje (temperature, glasnoca), kako se kloka...
Prije nego se upustim u kupovinu volio bih znati osnovnije stvari o ovom modelu.
Prilazem i link da se tocno zna o kojem modelu pricam: http://tinyurl.com/68l5gw
Verbum je offline   Reply With Quote
