od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Treba mi malo racunalo
Poz želio bih si kupit za turisticku agenciju kofu koja ce sluzizi samo za internet da se ljudi mogu sluzit sa njim!!! znaci, monitor i ostalo se snadjem ja, ali treba mi neko malo kuciste (mini) moze biti i gotova konfa, samo da na nesto lici. malo sam trezio po ducanima, ali nemaju nista gotovo ideje??? hitno mi je
Postovi: 483
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ... |
od LemilicE
Postovi: 4,712
odlicno, ali nekako sam uspio nabasat na ovo http://www.feniks-kompjutori.hr/inde...irnije&id=2955 hvala!!! moze lock
klanfa
Lokacija: ZG-Dubrava
Postovi: 494
Desk Top Eurocase 3D01, Micro Tower, ATX, 7 slots, 1xaudio Power- 243,90Kn ASUS P5GC-MX/1333, ASUSTEK, P5GC-MX/1333, 775, Intel® 945GC-368,25Kn Procesor Intel Celeron 430, 1.8GHz, socket 775, 512Kb cache-303,17Kn DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5-110,00kn HDD Samsung 80 Gb, Serial ATA II, 7200rpm, 8Mb cache, SpinPoint-280,97Kn DVD Rom Liteon 16x black, SATA-107,60Kn Adm za cash 1.414,00kn ili nekaj ovak http://www.arhiteh.hr/shop/index.php...oducts_id=2586 http://www.arhiteh.hr/shop/index.php...oducts_id=3074 http://www.arhiteh.hr/shop/index.php...sort=4a&page=2
In the ghetto
Postovi: 1,943
Za dvije tisucice slozis vec posteno racunalo koje moze sluziti za puno vise od nekakvog info pulta i koristenja internetom: mbo - Gigabyte P31-DS3L, s775, intel P31+ICH7, FSB 1333/1066/800MHz, 4 cpu - Procesor Intel Pentium Dual-Core E2180 , 2.0GHz, socket 775 BOX ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5 x2 vga - VGA Ati Radeon X1650 256Mb DDR3, 128bit, TV out, DVI, PCI X hdd - HDD Hitachi GST Deskstar T7K250 160 Gb , Serial ATA II-300 , 72 dvd - DVD upisivač Liteon DH-20A4P-06C, 20x , DVD-Dual, black, ATAPI, psu - Napajanje FORTRON 400W, PNF serija, PFC, Super Silent, 12cm vent cas - Aplus CS-185A PC Case, w/o PSU, RoHS 2.212,97Kn sve iz www.adm.hr A za cca 1500kn se moze slozit kutija koja ce te sluziti stvarno solidno za nevedene potrebe: mbo - Gigabyte MA69VM-S2,AMD 690V, Radeon X1200 shared, 2PCI cpu - Procesor AMD Athlon 64 X2 4200+ , socket AM2, BOX ! , 0.09, 1024 ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5 hdd - HDD Hitachi GST Deskstar T7K250 160 Gb , Serial ATA II-300 , 72 dvd - DVD upisivač Liteon DH-20A4P-06C, 20x , DVD-Dual, black, ATAPI, psu - Napajanje FORTRON 350W, PNF, Super Silent, 12cm ventilator, ATX2 cas - Colors-it L8027-C43, bez napajanja, midi tower 1.583,61Kn sve iz www.adm.hr
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor Zadnje izmijenjeno od: elvis again. 08.05.2008. u 22:32. |
Suit up!
Postovi: 5,972
Ili jednostavno kupiš neki dobar brand name (lenovo/hp/FS) sa predinstairanim windowsima (ukoliko se koriste u firmi) i s backup particijom tako da se u slučaju bilo kakvog problema lako vrati na tvorničko stanje bez da se 2h zayebaješ s tim.
#7 | |
klanfa
Postovi: 494
ova 2. konfa je sasvim uredu i ne treba mu više od toga
Zadnje izmijenjeno od: McG. 09.05.2008. u 14:25. |
In the ghetto
Postovi: 1,943
@BOGDO: sastavil sam konfu do 2200kn samo da moze videjti kaj moze kupit za te novce umjesto onog kaj je on predlozil iz feniksa. Naravno da mu netreba jaca ili skuplja konfa od sluvcaja br. 2.
#9 | |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
od LemilicE
Postovi: 4,712
to sm i ja skuzio kada sam ih zvao ![]() ![]()
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Eto mogao si usparati koju kunu da si tatu poslusao Kupi desktop case, neki Frontier i spici u njega mATX Abit plocu za 300kn sa nVidia integrirkom, Celerona E1200, Kingmaxe i imas fin stroj za sitne pare. ![]() http://www.links.hr/index.php?naziv=...kl=050.306.309 ![]() http://www.links.hr/index.php?naziv=...kl=052.603.018 |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,784
Zasto ne pogledas IBM SSF Thinkcentrove? Moze ih se dobiti u pristojnim konfiguracijama i operativnim sustavom vec od 3kkn...
Lokacija: Zagreb, trešnjevka
Postovi: 1,166
Zovni ovu firmu, http://www.pondi.hr/ imaju pravu stvar racunalo veliko kao dvije kutije cigareta tocno dovoljno za ono sto tebi treba, Nalazi se u malenom kucistu i najnormalnije se spaja na monitor, tipkušu, miš. Mislim da kosta 1200kn + sd kartica proizvoljne velicine (umjesti harda naravno) |
Lokacija: Orahovica
Postovi: 7,363
jel imas mozda malo vise detalja o tome? pretpostavljam da je to ovako nesto bazirano na ITX standardu http://www.thg.ru/mainboard/19971201/print.html |
al se nekad dobro jelo...
Postovi: 3,312
Pogledaj MSI Titan: http://www.svijet-medija.hr/Article....=16392&sid=154 24 x 18.5 x 7 cm Vidio sam ga uživo i stvarno je picolo! ![]() http://www.trustedreviews.com/images...mmary/7552.jpg - usporedba gabarita sa limenkom cole.
Zenfone 9 | Zephyrus M16 | HP Chromebook X2 | Tesla Model Y LR |
