Staro 19.04.2008., 16:37   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Nvidia’s Core-Logic Data Corruption & Overclocking
Zar opet?
Nvidia Corp., a leading designer of graphics processors and chipsets, recently admitted that its most-recent chipset for Intel Corp.’s microprocessors may cause data corruption in case processor bus and system memory are overclocked. Earlier customers blamed previous-generation Nvidia’s core-logic sets for data corruption under the same circumstances.
Apparently, when computer enthusiasts overclock processor system bus (PSB) and memory clock-speeds on systems that are based on Nvidia nForce 790i-series core-logic, they may experience data corruption on hard disk drives. Earlier end-users complained about the same issue on systems powered by previous-generations Nvidia nForce chipsets.
“Nvidia has received reports of data corruption when using certain high speed memory and overclocking the front side bus. Our engineers are currently investigating this issue and as soon as we have more information, we will provide an update to this knowledge base article,” a statement by Nvidia in its technical support forums reads.
Even though this is not the first time when customers complain about data corruption, neither Nvidia nor any of the mainboard makers have disclosed the reasons of the problem.
Nvidia nForce 790i Ultra SLI core-logic supports Intel Core 2 processors with up to 1600MHz processor system bus and overclocking capability beyond that, dual-channel DDR3 memory with speeds over 2000MHz, three PCI Express 2.0 x16 slots for graphics cards, six Serial ATA-300 ports for hard disk drives and so on.
http://www.xbitlabs.com/news/chipset...g_Company.html
Staro 19.04.2008., 16:45   #2
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Hehehe dobro je da neke stvari uvjek ostaju konstanta u stalno promjenjivom IT svijetu...
Have a nice day...
Staro 19.04.2008., 17:04   #3
Jelc
Super Moderators
Postovi: 17,485
Kad se samo sjetim kak su se špinčili da KT400 nema PCI lock a NF2 ima...pa se nastavilo sa problemima vezanim kaj za chipset kaj za opjevane sw ide drivere
Citiram:
Idemo dalje.
Kraj citata.
Mali savjet-koristite MS drivere i ne overklokujte svoj računar ako imate Nevidia chipset
Staro 19.04.2008., 21:58   #4
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ae ae nf2 nije bio tako (jako) los. to sto imaju sljepce u odjelu za pisanje drajvera svakome se desi
uostalom oni ustvari paze na svoje kupce
.i.
Razer Blade 15
Staro 19.04.2008., 22:39   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
NF2 je imho jedini Nvidia chipset koji je valjao (prvenstveno zbog Soundstorma), NF4 donekle, jer je bio jako eksponiran (sve najbolje ploce iz tog doba su ga imale), iako nije bio superioran VIA-inom K8T890 (dobro sam vidio sta taj chipset moze).
O Nvidia chipsetima za Intel procesore da ne govorim. Nijedan nije valjao, mozda zato sto su Intelovi chipseti toliko dobri.
790i je svejedno sranje od chipseta, bez obzira na ove probleme.
Staro 19.04.2008., 22:55   #6
Jelc
Super Moderators
Postovi: 17,485
Pa, chipseti za AMD i nisu toliko loši, ali bi se o legendarnim driverima dalo razgovarati.
Kad se samo sjetim kako je net uzduž i poprijeko bio zaglušen drekom nestretnih usera koji su zla ne misleć i ničim izazvani išli instalirati "Hardware-Based Firewall and ActiveArmor" điđice pa su se na službu za korisnike javljali isključivo sa susedovog kompa...
Staro 20.04.2008., 00:47   #7
yedwy
yedwy's Avatar
Postovi: 6,956
Hehe kako ne kužiš oni su skužili pravu i veliku istinu, jedini način da napraviš stvarno siguran komp je da korisnika izbaciš iz jednadžbe i to su i napravili...
Have a nice day...
Staro 20.04.2008., 12:01   #8
Jelc
Super Moderators
Postovi: 17,485
I meni se čini da su se vodili tom idejom
Staro 20.04.2008., 12:45   #9
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,758
Autor Jelc Pregled postova
Zar opet?
Dobro, cekaj malo, sto tu tocno oni imaju "priznati"? Korisnik izlazi izvan zadanih parametara proizvoda i *cudi* se otkud problemi - sto je tu za nVidiu tocno sporno? OK, znam da im prodaja ovisi o overkloukerskim hakerima kojima je glavna zanimacija imati , iz ne bas nekog pretjerano inteligentnog razloga, ovrkuklokukano sve sto ima takt, ali nije ko da u Nvidiji nemaju pametnijeg posla...
S druge strane, vec vidim jedan dan na vijestima na PcE - "Pobjesnjeli haker tuzi nevidiju jer izgubio screenshotove svog svjetskog rekorda u superpiju".
Programer
Staro 20.04.2008., 13:13   #10
Jelc
Super Moderators
Postovi: 17,485
Autor Bubba Pregled postova
Ne moraju oni nikaj priznat-svaki mazohista koji drži do sebe ima kombinaciju Nevidia chipset/Pentijum, nije to ništa novo...ali ako u BIOS-u imaš "overclock" tab sa opcijama za clockanje...molim lijepo...
Nije taj BIOS napravio mali Ivica u kućnoj radinosti nego Nevidia.
Znači-to je ipak regularna opcija a ne nekakav izlazak iz regularnih parametara proizvoda.
Staro 20.04.2008., 20:38   #11
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,941
Samo jedan mali komentarčić na post iznad mene. Prije par godina kad ste kupovali matičnu,grafu, kaj god, u menjuelu ste mogli pročitati poruku tipa : Primite na znanje da OC smanjuje stabilnost sistema i povećava mogućnost neispravnosti komponenti.
Danas kupite i pročitat će te poruku : Primite na znanje, OC opcija vam je u BIOSu , ili preko xxx programa .
Toliko o tome
Staro 20.04.2008., 21:47   #12
Jelc
Super Moderators
Postovi: 17,485
Autor m4dm4n Pregled postova
Toliko o tome
Toliko o tome da komentiraš a očito ne znaš ni osnovni info o tom chipsetu...
Budući da se radi o najskupljim pločama (rang 300$-450$), pločama koje se i reklamiraju za overclocking-vjerovao ti ili ne ti ljudi koji su utukli toliki novac u svoj stroj ne žele da im propadnu podatci.
A bogme ni nisu iskrcali brdo para da bi vozili na default postavkama.
DDR3, SLI ili Quad SLI u Ultra inačici, napon za proc do 2v...kad se složi takav stroj cifra je poprilična.
Ili kako je to Nevidia najavljivala:
"The Fastest, Most Overclockable Rig"
Toliko o tome
Nećemo ni pričat o tome da se radi o ploči koja se špinči sa NVIDIA® MediaShield™ Storage điđom...
Staro 20.04.2008., 23:56   #13
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Drito ovo sto je Jeltz napisao. Ploce od 400$ koje koruptiraju podatke kad ih kloknes?
Staro 21.04.2008., 00:18   #14
Razer
Razer's Avatar
Postovi: 11,642
Baš me zanima u kojim situacijama...
Možda sa SATA diskom i PCI-E sabirnicom na 150MHz+
Staro 21.04.2008., 00:20   #15
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,758
Postoji nesto sto se zove standard i postoji nesto sto se zove PC (starohrvatski: nepostivanje standarda). U ovom slucaju, konkretno, Intel je taj koji daje standardizirane specifikacije a nVidia tj. korisnici ih krse. Egzistencija opcije u BIOS-u ne cini pothvat opravdanim, niti kukanje na konto toga.
OTOH, sto se tice tvojeg smijesnog referiranja na cijenu - postoje ploce za PC koje stoje reda velicine 1000$, pa na njima uopce nema "overclock" tab s opcijama za clockanje.
"Entuzijasti modernog doba" ciji je maksimalni Grunfovski pothvat promjeniti tri opcije u sarenom BIOS-u jos uvijek nisu svjesni da njihovi poduhvati, ma koliko ih "sponzorirali" neki, jos uvijek ne samo da nisu profesionalni, nego donose i tisuci i jedan potencijalni problem.
Naravno, zalosna je istina da bi ukidanjem ouvrklouka nVidia (i ne samo oni) popusili big time, no to samo govori o profilu tipicnog home PC usera - no to je vec neka sasvim druga tema...
N'da, ako se kloka s nevidijom, to jamacno onda mora biti po PS-u...
Programer
Staro 21.04.2008., 00:42   #16
Jelc
Super Moderators
Postovi: 17,485
Smješno je kaj ti spominješ ploče od 1000$ pa na gore a mi tu pričamo o sasvim desetom segmentu tržišta...
I da, 300$-450$ za ploču nije malo.
Dakle-najskuplja ploča sa tim chipsetom.
Namjenjena i reklamirana kao overclockerska.
Ono :
Get unbeatable performance at stock and overclocked speeds (single GPU). NVIDIA nForce 790i Ultra SLI MCPs offer the highest CPU FSB overclocking with the latest CPU technology as well as unrivaled DDR3 memory overclocking. And real-time component monitoring and tuning features with ESA give you complete control over your PC."
je sa Nevidia službenih stranica...
Rezime-napravili su skupu overclockersku ploču koja ti ubije boga na harduljku kad je-pazi ti to clockaš
Za krepat
Na stranu korisnici koji su popušili sa ovom pločom (Quad, superskupi DDR3, SLI ili Quad SLI-dakle brdo para), ovo nije prvi put da dolazi do korupcije podataka sa Nevidia chipsetom.
Bogme nije ni drugi put
Koliko se sjećam-prije nisi ni morao clockati da bi došlo do korupcije podataka...
I kaj su naučili iz svega toga-ništa
Staro 21.04.2008., 06:58   #17
yedwy
yedwy's Avatar
Postovi: 6,956
Da ali su to useri koji čine dobar dio tržišta i bez kojih nebi bilo niti ostatka ITa... Vrlo jednostavno - da nema nas vulgaris usera nebi bilo niti potrebe za tolikim serverima (i administratorima istih dabome) i imali bi situaciju iz 60ih i 70ih kad su samo vlade i tech sveučilišta i uber velike firme imale nešto osnovnog mrežnog potencijala i trebale servere, ono što Internet i IT čini tako profitabilnim i tjera razvoj upravo je masovnost, a ne ekskluzivnost iliti da average suburban Joe oće potrošiti svake godine 500-1000$ na upgradeove kompa, mobitela itd...
E da i propo standarda i ostaloga, vidim da prodaješ svoju BA2 ploču, nije vrag da nije baš tako standardna kako bi trebala bit sa svojim "standardiziranim specifikacijama" jel....
Have a nice day...
Zadnje izmijenjeno od: yedwy. 21.04.2008. u 07:17.
Staro 21.04.2008., 08:52   #18
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,758
Autor yedwy Pregled postova
Ostalo necu ni komentirati, ali ne, omasio si ceo futbal. Holisticki, vecina korisnika niti overklouka, niti renderira, niti se igra, niti tjuna latencije, niti skida svaki dan nove drajvere. To sto *dobar dio* nVidiinih (primjerice) korisnika to radi je nesto sasvim deseto i nema veze s IT-om kao takvim.
Ovo je bio (los) pokusaj tocno cega? Imas li uopce pojma zasto prodajem BA2 tj. koji su razlozi za prelazak na Tyana?
Autor Jelc
Ovo je bilo zlocesto, a opet tako istinito - no obzirom da dolazi od fanATIka...
Programer
Staro 21.04.2008., 10:53   #19
Jelc
Super Moderators
Postovi: 17,485
No,no...istinabog da imam samo ATI grafe...ali sam imao i NF2, NF4 Ultra i sad imam isto Nevidia 590 SLI chipset
Čak sam i overklokovao svoj računar
Ne znam zakaj svi misle da ja ne volim Nevidiu
Staro 21.04.2008., 11:21   #20
yedwy
yedwy's Avatar
Postovi: 6,956
Gle buba znam vidio sam onaj post koji si stavio oko diskovlja i da točno većina usera ne kloka mašine i zapravo ih nije niti briga kaj je uopće unutra i to stoji kaj veliš ali to ne znači da je ono kaj sam rekao manje istina, jer vidiš i sam da je dio koji kloka ipak značajan čim rade se takve ploče jel...
To kaj ti ne spadaš u tu skupinu je već nekaj drugo...
Osim toga sam si vidio sa pločom (koju pretpostavljam da nisi nikad niti klokao) da nije baš sve crno bjelo jel (a perjanica je ponude tog istog Intela nije li, tj ex perjanica ali nema veze) i da ne radi kako bi trebalo u jednom od segmenata koji bi kod takve ploče trebao biti skoro pa i najbitniji (mislim server/workstation/extreme PC ploča pa storage šteka???), sad ta greška ili bolje rečeno neoptimizacija koja tebe muči vjerojatno nebi mučila 99 od 100 korisnika ali eto postoji i tebe muči što opet nešto znači, možda je posljedica greške u čipsetu ili u ploči kao ploči to neznam, ali ako se zna da je cjela serija SVIH ploča baziranih na nečemu (aludiram na povod ovom threadu) u startu omašena počne se pitati koji k rade tamo ti dizajeneri čipseta, isto kao i smojom pločom i pržom, ima BSOD sindrom kad se koristi onboard zvučna i prža u isto vrijeme, neko je napisao da je to posljedica "neslaganja" čipseta ploče i čipseta prže, to je idiotluk od strane proizvođača mislim ja se fakat ne sjećam da mi na prži igdje piše "ne radi sa nf4 čipsetom kako treba"...
Have a nice day...
Zadnje izmijenjeno od: yedwy. 21.04.2008. u 11:51.
Staro 22.04.2008., 09:18   #21
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,758
Ja moram priznat da nisam napravio detaljnu evaluaciju niti jednog nVidiinog chipseta iza nF2 (a osobno sam dugo vremena imao i radio na Crush12 (nF 420D) i raznim varjantama nF2 jer su u to vrijeme zaista nudili fantasticne performanse koristeci integriranu grafiku (tada je onaj njihov cuveni "dual channel" postao itekako primjetno i dobrodoslo ubrzanje, jer se citav kanal dedicirao za memoriju GPU-a) a ni Soundstorm nije bio za baciti.
Nazalost, ni od tada nisu uspijeli rijesiti nekakve djecije bolesti na desktop chipsetima koje ih pate i svrstavaju ih u kategoriju neozbiljnih i nepozeljnih proizvodjaca chipseta. OTOH, uopce nisu napraviti los posao na Opteron based plocama sa svojim MPC+IO rjesenjima.
Pas mater, zakaj si pobrisao onaj lijep i uvredljiv post? To boli, znas...
Znacajni dio iz perspektive korisnika PiSiEksperata. PiSiEksperti su strahovito malen i skoro pa zanemariv dio citavog IT svijeta. Gdje se ne overklokira. Ne tjuna i ne stima latencije. Ne renderira high quality p0rn. O tome je bilo rijec. Nedvojbeno su klokeri, tvikeri i superpi korisnici veliki dio *njihovog* trzista. No sve u svemu, globalno, taj dio je zanemarivi reprezentativni primjerak da bi bilo potresno to sto izlazenjem iz standardnih specifikacija - stvar ne radi onako kako je zamisljeno.
Aha. Ja ono pripadam u skupinu kretena koji misle da su najpametniji na svijetu, ako se ne varam?
/snip
Da, slazem se s tobom, ali izbor ploce je *moja* greska, ne greska proizvodjaca. Naravno, nigdje ne pise "totalno smo sjebali apsolutno svaki bitan dio ploce osim ouverklouking dijela, ali to ionako nije bitno, o glupi korisnice, jer ces kupiti tu plocu da klokujes i tjunujes, a ne zato sto ima legacy portove, 3x PCI-E koji ti trebaju za multi monitor konfiguraciju a ne za ganjanje 706 kartica u SuperMegaSLI-ju ili dva PCI-a u koja ces u najboljem slucaju staviti dodatni USB kontroler za svoje neonke, a ne dva(!) SCSI kontrolera (i to nedajboze RAID, jer, kao sto mi je Intel lijepo objasnio, ako hocu ganjati RAID kontrolere, trebao sam uzeti nesto iz "Server" ponude, op.a)".
Kao sto rekoh - my bad, u potpunosti.
Programer
Staro 22.04.2008., 11:46   #22
yedwy
yedwy's Avatar
Postovi: 6,956
Zato jer sam pročitao još jednom i zaključio da nisi zaslužio onakav uvredljivi odgovor (ovaj puta) iako znaš i sam da nekad fakat nastupaš tako da...
Mislim nisam niti ja niš bolji nekad i to je istina, svi nekad malo patronizirajuće nastupamo...
Nisam rekao riječ kretena, prava fraza je bila ako se dobro sjećam "to što misliš da si najpametniji i da ti je tvoj sud konačan, ne znači da je tako" i iza toga stojim...
To što ti neki feature smatraš suvišnim ne znači da i jest, a ako nečega nema a misliš da treba opet ne znači da tako misli proizvođač, svako bira kaj mu se najviše sviđa...
Ali ako neku ploču platim 1200kn (bilo to za porn ili bilo kaj drugo) radi toga jer ima OC opcije i sl ipak ne znači da oću da mi skoruptira podatke...
Da my point exactly - ne piše shebali smo jedan od najbitnijih featurea koji ploča može imati, da si znao nebi je kupio, i to je jako gadno za ploču koja košta tolko i bila je vrhunac vrhunaca ponude tog Intela, to je i bila poanta na ono kaj si rekao o standardima - da i sam vidiš da sam onajk koji je te standarde izdao ne poštiva baš to... Tja...
Have a nice day...
Staro 22.04.2008., 12:00   #23
syss
syss's Avatar
Postovi: 10,805
od svega spomenutog ja bi samo htio da se ne blati nf2 nepotrebno
driver sim-tam, tko je imao net i google to je riješio za pol sekunde ili uopće nije imao potrebe rješavati (imao sam i nf2 plain i kasnije 400 nisam imao problema sa nvidia ide driverima), dok sa druge strane imamo na ovom forumu 3-4 stranice veselih catalyst korisnika koji gledaju hd preko svojih state-of-teh-art drivera
Staro 22.04.2008., 12:17   #24
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ja sam odmah napisao da je NF2 bio dobar chipset, dapace odlican. Problem je sto ostatak nije takav.
Sta ce mi chipset koji trosi vise od procesora? (hint: 790i i kakav C2D)
Staro 22.04.2008., 12:28   #25
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,758
Point i jest u standardima - da sam se htio inatiti (a imam dobre razloge zasto nisam htio), ta ploca bi davno bila proglasena neispravnom buduci da nema operativne osobine za koje proizvodjac garantira (33MHz 32 bitni PCI po svim svojim specifikacijama i pravilima je jedan od tih "nedostataka", jer mi je nedostupno preko 30% bandwidtha sa hardverom koji se sposoban za mnogo vise).
Jedini gorak okus je, kao sto si i rekao, sto je ta ploca navodni "vrhunac Intelove ponude".
Programer
Staro 22.04.2008., 13:34   #26
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,844
Dečki...prepirete se bez veze.Bubba je jednim dijelom u pravo i to onom da ako neka firma kaže da njihov proizvod može to i to onda on to mora i u stvarnosti moći bez ikakvih negativnih posljedica,jer inače je to lažno reklamiranje što bih osobno najstrože kažnjavao....Dakle-ako ploča ima RAID te piše da radi-onda jebemu miša on mora radit kako RAID i treba raditi bez ikakvih štucanja.Ako on ne radi kak spada na toj ploči,bolje ga maknut i reći "nismo stavili RAID na tu ploču jer s obzirom na isplativost i konačnu cijenu proizvoda on bi bio loš"...al tu dolazimo do krute istine-svima se njima lijepo j*** za sve nas i tretiraju nas kao što je Bubba i opisao-naivne kupce koji vjeruju svemu što marketing kaže...a to nas opet dovodi do klinaca koji sebe nazivaju hakerima,overklokerima i gejmerima koji kupuju iste proizvode da bi ostali bili zavidni na njih jer oni to imaju a oni ne (čast izuzecima)...to što se nezanju koristiti istima-ma koga šiša,glavno da on/ona to ima...a to prodavači vole jer znaju da će na taj način se ta "bolest" proširiti na većinu ljudi i oni će dobit svoj mali trgovački raj (prodaja muda pod bubrege)...Ako još niste shvatili,živimo u kapitalističkom društvu gdje je centar svijeta novac i trgovina i u čemu ne vidim ništa loše dok god ne dođe do prodaje na štetu ljudskih vrijednosti....
Staro 22.04.2008., 13:48   #27
Jelc
Super Moderators
Postovi: 17,485
Oksimoron, totalni
Staro 22.04.2008., 14:32   #28
yedwy
yedwy's Avatar
Postovi: 6,956
Da shvaćam te, nemaš vremena za takve gluposti, i prečesto upravo zato i prolazi sve to...
Da upravo to i je žalosno i poanta cjele priče...
Ajd živio mi i sretno sa zamjenom iste zanešto bolje...
Have a nice day...
Staro 22.04.2008., 16:48   #29
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
potpisujem bubino.
"ova kumica mora prestat prodavat sir, jer ona kumica do nje ima finiji sir". iako su oba sira zdrava i po svim standardima, itd.
kupi i jedi kaj ti odgovara, al nemreš kumici reći da mora prestati prodavati sir zato kaj ova do nje po istoj cijeni ima sir koji je tebi finiji.
možda ja volim baš sir koji je tebi manje fin, zato kaj mi je malo manje bitno da bude fini odmah kad ga kupim i jedem s friškim kruhom i mladim lukom, nego kad ga napravim sa tijestom. get my point?
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 22.04.2008., 18:11   #30
Jelc
Super Moderators
Postovi: 17,485
Nja, nja, nja...
Svi nekaj potpisuju, pričaju o standardima, IT-u...
Stvar je jednostavna:
Usrali su motku sa chipsetom prije (obećavali brda i doline a pomaka nije bilo)
Zajebali korisnike (poznata fora o špinčenju sa RAID-om koji je po njihovom infu trebao bit malo tvrđi a ispao je žmefki)
Zanimljivo je da to nije nitko ni spomenuo a svi kao prate...
I najvažnije kaj se tiče standarda-nije to Nevidia napravila i bacila na tržište bez testiranja i blagoslova od strane Intela
Ne ide to baš tak kao neki misle...
Molim lijepo-spike o pločama za ozbiljan rad ostavite po strani, pričamo o najačoj ploči za "vulgaris" korisnike.
Najskupljoj ploči za taj segment tržišta.
Ploči reklamiranoj i na kraju krajeva i predviđenoj za overclock ili igranje...na šarenoj kutiji će pisati da možete staviti svoje dvije-tri 9800 GX2, ubost najači Quad, DDR3 memu, to sve clockati i biti najača manga u kvartu
Neka mi netko od poštovatelja standarda pošalje PDF od Tyanice u kojem dotična firma vabi kupce na tu spiku...gdje će kupac te ploče dobiti soft-RAID a da to nije napomenuto u specifikacijama, gdje će vam obećavati mrak perfomanse, Tri-SLI i clockanje vašeg najnovijeg Quada do neslućenih granica...i sve to u kompi sa DDR3 memom?
Ne, naravno da Tyan neće navlačiti svoje kupce na takav način-to je firma koja je poznata po pločama za ozbiljnije stvari.
Nema apsolutno ništa loše da netko kupi ploču za gejmanje ili overclock, najbolju i najskuplju na tržištu.
Fakat ne kužim zakaj kad se spomene opaki bug na takvoj ploči prvi skaču u obranu lika i djela ljudi koji nit gejmaju, nit clockaju...niti bi kupili takvu ploču taman da dobiju na lotu
