#121 | |
Lokacija: tam negde :)
Postovi: 290
--------------------------------------------------------- Ping statistics for 67.205.87.235: Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)... --------------------------------------------------------- Tracing route to alertpay.com [67.205.87.235] over a maximum of 30 hops: 1 3 ms <1 ms <1 ms 192.168.1.1 2 19 ms 16 ms 16 ms 172.29.252.59 3 16 ms 16 ms 16 ms 172.29.1.233 4 35 ms 34 ms 34 ms 195.22.196.81 5 61 ms 61 ms 61 ms 195.22.211.213 6 65 ms * 66 ms 80.81.193.114 7 76 ms 76 ms 76 ms 80.231.64.13 8 59 ms 60 ms 59 ms 80.231.64.34 9 146 ms 145 ms 145 ms 216.6.114.45 10 158 ms 145 ms 145 ms 216.6.114.14 11 165 ms 163 ms 163 ms 206.82.135.26 12 * * * Request timed out. 13 * * * Request timed out. 14 * * * Request timed out. 15 * * * Request timed out. 16 * * * Request timed out. 17 * * * Request timed out. 18 * * * Request timed out. 19 * * * Request timed out. 20 * * * Request timed out. 21 * * * Request timed out. 22 * * * Request timed out. 23 * * * Request timed out. 24 * * * Request timed out. 25 * * * Request timed out. 26 * * * Request timed out. 27 * * * Request timed out. 28 * * * Request timed out. 29 * * * Request timed out. 30 * * * Request timed out. Trace complete. -------------------------------------------------------- fakat zanimljivo..stranicu mi hoće otvorit...al bilo kaj "submitam" (u ovom slucaju logiranje) - nista...cak mi niti djelovi FAQ-a ne rade...na IE sam se uspio logat...al nece se odlog-at da ga....ahh.. Zadnje izmijenjeno od: McT.. 16.04.2008. u 19:03. |
#122 | |
Lokacija: vž
Postovi: 1,331
![]() sad ili imaju problema ili mainteinance ili cistacica odstekala neku mashinu u server sali jer usisava ![]() |
#123 | |
Postovi: 290
![]() ![]() edit: System Upgrade Today The system will be down for scheduled maintenance between 3:00 and 4:30 PM EDT today The system will be down for scheduled maintenance between 3:00 and 4:30 PM EDT today. We are working hard to improve the AlertPay user experience. We appreciate your patience while we make improvements to our system. |
#125 |
Lokacija: vž
Postovi: 1,331
#128 |
Lokacija: Zagabria
Postovi: 492
#133 |
Postovi: 44
par pitanja zašto na forum od bux.to se nemože logirat dobijem svaki put Sorry, we could not find a member using those log in details. šta upisat na karticu nemogu se stavit slova ćčšđž pri upisu imena prezimena |
#134 | ||
Lokacija: Vinkovci
Postovi: 82
![]() Ideš na wire transfer. Recimo uplatiš 40$, na AlertPayu ćeš imat 20$, a drugih 20$ odoše.. Pa tebi na volju.. ja ne preporučam.. Citiraj:
Na karticu upišeš bez naših slova.. Zadnje izmijenjeno od: Jelc. 18.04.2008. u 21:50. |
#135 |
je.ba.c na ba.te.ri.je
Lokacija: Zagreb-Jarun
Postovi: 304
jel ima neko poseban link ili ?????? jel recimo ja sam premium user i kad klikam po oglasima ima jedan oglas u vezi zatrazivanja doticne kartice ali kad kliknem na njega pise "please login" a ja sam logiran..... tak da ne kuzim..... ako si voljan posalji mi link na pm ak nesmijes tu.... |
#136 |
Lokacija: Vinkovci
Postovi: 82
#137 | |
Postovi: 304
ako malo bolje pogledas na slikici ja vec jesam logiran http://img247.imageshack.us/img247/5074/24071882fl9.jpg |
#139 | |
Lokacija: Vinkovci
Postovi: 82
#145 | |
Lokacija: Vinkovci
Postovi: 82
![]() Kako tako dugo?? Pa trebaš ih dobit odmah sljedeći dan, najkasnije 2 dana.. Da te pitam.. Nisi valjda unio pri kupovini drugačiji email od onoga u Bux.to profilu?? Ako jesi onda moraš slati ticket jer inače ne mogu povezat pare i account.. |
#146 |
Postovi: 71
Htio bih reci da bux.to isplacuje uredno i stvarno se isplati uloziti novac, prijatelj je dobio na alertpay novce. AlertPay ti salje na kucnu adresu cek, to sam isprobao dal radi i stvarno sljaka. Dobio sam od druge stranice www.dailyclicks.biz isplatu na alertpay nekih 45$ i najnormalnije unovcio cek u zagrebackoj banci. Zamolio bih ak je tko voljan nek se rega. Isto tako na bux to sam ulozio oko 160$ i trenutno imam oko 870$. Htio sam reci imam i bux.to karticu i super izgleda cekam svoju prvu isplatu na nju trebala bi uskoro stici. Prijatelju su kasnili pol mjeseca tako da ce i meni. Stranica ima cca 3.5 miliona korisnika i Alertpay trenutno ima problema sa svojim serverom tako da malo sporije idu isplate ljudima na alertpay racune dok na kartice redovno idu isplate. Uskoro tj. tocnije 1.5. bi trebala bit postavljena nova skripta za bux.to znaci brze bi isplate trebale biti. Svi se vesele tome, iskreno ja jedva cekam svoje pare nekih 380$ da mi sjedne Zadnje izmijenjeno od: maxrox. 26.04.2008. u 22:22. |
#149 | |
Lokacija: NaN
Postovi: 3,438
#150 |
Lokacija: Vinkovci
Postovi: 82
Na BuxBB Forumu odlična vijest. http://buxbb.com/index.php?showtopic=35423&st=0 Kako imaju problema s AlertPayom, isplate na karticu su u prednosti.. Dakle ako Bog da mogao bih dobiti pare s nevelikim zakašnjenjem, a ako dobijem i prije roka onda pazite da vam sjekira ne padne na glavu.. Cheers! ![]() |
